crust45833
I am running a micro atx MSI board with an athlon64 3000+ which I was hoping to overclock and put in the computer with my x850xt, but it was running really high temps with everest, so i took out the x850 to see if it was drawing too much power, but that appeared not to be the case, everything runs fine, including games with no overheat crashes yet, but I am very concerend, as the venice core usually runs much cooler. I am using the aspire 420w PSU that came with the case, and it is 20 pin, dont know if that is an issue or not, if it could be running hot due to low voltage, is there a way to check the voltage ratings with a program? I couldnt find it in my bois. Thanks in advance any help would be greatly appreciated.
