SlowSpyder
I have an Athlon XP-M 2500+ and a DFI Nfinity motherboard. I'm using 1 gig of Corsair value select ram and a GeForce 6800nu. When I run the processor at the stock 133 x 14 speed everything runs fine. If I up the bus speed to 166 and lower the multiplier to 13 it runs 95% stable (for lack of a better way to describe it). And if I run a 200 mhz bus it doesn't matter if I run a 9x multiplier or a 12x multiplier, it runs only somewhat stable. I can adjust my voltage anywhere between 1.65 and 1.85 volts, it doesn't seem to matter, the stability doesn't get any better. Also, at the 200mhz bus speed it seems my data starts to get corrupt, and I fail Prime95 in like 30 seconds. Temps recorded by the motherboard seem ok until I get to the 1.8 volt range where the CPU starts to get to upper 40's/low 50's. I'm using a Thermalright copper cooler and a 92x25mm fan with Artic Silver 5. I just reformatted and rebuilt the PC last night as Windows stopped loading with a ".dll needed for kernal were not loaded" error appeared while trying to use the 200mhz fsb. Right now I am running 133x14 until I can figure out a fix. Also, I have booted into Windows as high as 2.6ghz (200x13) but stability was horrible. My power supply is an Aspire unit, the 12volt rail is rated at 34 amps, if I recall correctly.
Please help! 🙂
Please help! 🙂
