Jeff7181
I keep reading this over and over and over and over... people saying 50 degrees C is too high. This simply isn't true. I'm on my 3rd XP2500, now a mobile, but the other two were regular desktop XP2500's... and ALL of them have run 50 degrees C or higher for months at a time without problem. I've even run one of them at 60 degrees C for nearly a month with no instability or other heat related problems. I also have an XP1700 Palomino that's been running 62-65 degrees C for 16+ months, and I had an XP1700 Thoroughbred that ran 55 degrees C for over 6 months with no problems.
Some people, especially the anti-overclocking group, are under the impression that heat kills processors. That's partially true, but 50 or 60 or even 70 degrees C is not enough to kill a processor. AMD's Athlon XP's are rated for 85 degrees... the Mobile Athlon XP's (Athlon XP-M) are rated for 100 degrees C. As we all have heard recently, the mobile chips are made no differently than regular desktop chips, they're simply selected to be mobile CPU's because they are superior chips that can be run at lower voltages at the same speed, or higher speeds at the same voltages.
I know there is a certain margin of error that must be taken into consideration since AMD's specifications refer to the actual core temperature, not always the temperature being displayed by monitoring software that may be measured somewhere on or around the CPU socket, not the actual core itself. And then there's also a margin of error that should be maintained purely because you don't want to take a chance of overheating your CPU and damaging it. If we assume a 10% "margin of error" factor for the socket temp being read rather than the actual core temp, and another 10% for the "peace of mind" factor, you come up with about 70 degrees C being the high point.
So 70 sounds high to you? Does to me too... but AMD says it's ok. Granted this is at stock speeds, but it's my opinion that if your CPU becomes unstable when it gets warm, it's more than likely due to your overclock being unstable to begin with, and heat only exacerbates the instability. You can argue that the ability of the processor to reach higher speeds decreases as the temperature increases, but the reality of it is you're talking about only a few Mhz difference under these conditions, maybe tens of Mhz at the most... which only makes a difference to the most anal of us all who define their status as a human being by their score in PCMark, 3DMark, or some other synthetic benchmark.
Anyway... to end my rant... people, stop recommending that someone upgrade their cooling setup if their processor hits 50 degrees C... it is NOT necessary. If you're having problems with your CPU running at 50 degrees C, it's more than likely not due to the temperature, but rather some other weak link in your setup.
