- Feb 23, 2003
- 58
- 0
- 0
Hi, I am having problems with my xp 1800+ with ecs k7vta3 combo from fry's. Its the new jihxb stepping that is supposed to overclock well but at default speed its showing cpu temps of around 58 degrees celcius. This seems a little high also the heatsink fan is at about 4000 rpms? Is that correct or is that a participating factor to the high temp. I am pretty sure installed everything correctly but i will check. If i take the heatsink off after its already been used, will the thermal tape still be good or will i have to replace it? Thanks in advance, sorry for all the newbie questions.
EDIT: Also, this may be related to the heat, but the it seems that the IDE detection seems to be taken longer than average.
