Dual... Sweet! Hope you will join the AnandTech distributed-computing team and put all that goodness to use
When the first dual-CPU AMD board came out, it used a PSU with a special connector. Nowdays that is not generally the case, except for Tyan's Thunder K7-family boards. However, this unit and others like it were built for the demands of dual-AMD systems. I looked at the specsheet for the special PSUs that Tyan lists for the Thunder K7X, to try to gain insight on what amperage ratings are typical for powering a dual-AMD system, but came away confused. The Antec 510W unit is spec'ed lower than their TruePower 330 or PP412X in the 3.3 + 5 rating, while the Delta is a beast with 47A on 3.3V alone, and independent circuits for 3.3V and 5V. Most servers have more drives, but a typical enthusiast system compensates with a power-hungry video card.
If it were me, I would get an Antec TP430 or higher, or an Enermax 465 or 651, or maybe a Sparkle Power 400W or one of the PC P&C units if you want another. The PC P&C unit you have now would probably work, but it might have to strain when you ran the system hard.
