Athlon II x4 630 NB speed of 1600?
VirtualLarry
56,587
10,227
Is that correct? Athlon II X4 northbridge speed is only 1600, and not 2000 like on a Phenom II?
That's the speed that is auto-detected on my Biostar A760G M2+ mobo, that I bought at MC in a combo with the CPU (mobo was free). I didn't adjust any of the CPU frequency settings, they are all on auto.
RAM is DDR2-800, running at 800.
Could it be the mobo auto-adjusted NB speed to twice RAM speed automatically? Do I need DDR2-1000 to take advantage of a 2000 NB clock?
Vesku
3,743
28
86
Sounds like the motherboard BIOS just picked that speed. My Athlon X3 defaulted to 2000, it's running at 2100ish atm from OCing.
Eddie313
634
It might be your motherboard settings or bios update, I have a Amd x4 620 and it defaults to 2000mhz
formulav8
7,004
523
You need to see about a bios update. I had the same problem with a Biostar 790gx XE mobo with a Athlon II x3 440. It would default to 1600 mhz. (Although I could set it to 2000mhz manually.)
Once I updated to the latest bios it then defaults to 2000mhz. I simply turned the computer completely off then turned back on after the bios update.
Link: Here is a link to the bios page. I would think there is a newer bios than that. But if your boards bios is older then try with the one on Biostars site.
Jason
LoneNinja
825
Should be at 2.0Ghz, it's the specs on the processor and what my 630 defaulted at. My problem is the gigabyte 780g board I use defaults voltage to 1.4V, but in windows it reads 1.475V. If i set voltage manually to 1.375, or 1.425 for example, than I get that voltage in windows. I've also got a Biostar board that defaults my Phenom II northbridge at 1.6, it's got an updated Bios and it's annoying because I loose cool n quiet when I manually set northbridge speed. At least I preferred using K10stat over cool n quiet any ways.
VirtualLarry
56,587
10,227
You would tend to think that, wouldn't you. But I flashed the newest BIOS, from 9/09. That's the newest that they have listed for the Biostar A760G M2+ board.
http://www.biostar.com.tw/app/en/mb/bios.php?S_ID=394
Edit: Maybe it does it to save power? Since this is a 95W TDP CPU mobo.
Vesku
3,743
28
86
Biostar and Asus don't really support their low budget 760g motherboards. I have an ASUS m3a76-cm which is listed as supporting 125W cpus but they have yet to add any Phenom II x6 support. Also, they don't enable ACC on it even though it has a 710 SB. Very frustrating, I feel it's worth the extra 20 bucks to get a 785g board with much better support and updates.
LoneNinja
825
I've got 2 of the early 790GX AM2+ boards from Biostar, both produced back in 08, neither feature a bios update beyond Athlon II X4 support last fall. Oddly they list Athlon II, and even Phenom II 945 along with all other 125W parts on AM2+, but never listed support for the 955/965 and now they don't for Thuban either.
