ErikaeanLogic
- Feb 14, 2000
- 2,469
- 0
- 76
Originally posted by: stardust
Thank for your info!
I do very basic multimedia and intermediate photoshoping with files going as big as 150-200mb. I notice a considerable lag when using photoshop with lots of different effects and my current P4 @ 3.4 ghz, would the 64 3200+ be even slower?
hi,
Is the rig in your sig the one you are talking about upgrading? Because if it is, you need some more memory, in a bad way! 512MB (assuming this is what you're running on) is hardly adequate for anything more than gaming. I would say that 1GB is the bare minimum for anybody using graphics apps, 2GB is what I use since I use my comp for a digital darkroom, although my images are never more than 10MB. Also, where is your swap file? I believe that the best way to run a swap file is on another physical harddisk on its own partition. With 2GB of RAM I don't even run a swap file anymore, but with 1GB I had a 3GB partition on a harddrive other than my system-files harddrive and assigned that to be my swap file partition. Why did I do this? because of speed! Paging files are the leading contributor to drive fragmentation; every time you boot, however, the seperate page file partition can overwrite itself and will not interfere with the execution of system/app commands.
Just a thought
