athlon 64 3000+ (venice) and epox 9npa+ ultra, i need help!!!
dw33zil
8
just bought a venice 3000+ and an epox 9npa+ ultra yesterday and i ran ntune to boost system performance. it's now running at 2.08 ghz but i read in forums it could run faster. i'm using the stock hsf. is it possible to hit 2.2 ghz on stock cooling? here's the rest of the parts: geil ddr 400 platinum (512 mb x 2), winfast 7600 gs, a sata hard drive and a dvd writer. the bios has too many settings and probably would take me ages to figure out. hope one of you out there know a short cut (bios settings preferably) to get my system running at least 2.2 ghz. i just need extra performance because i can't afford to buy a system with higher specs.
Mucker
2,833
First, what timings does your memory have? Unless you got a subpar Venice your cpu should hit 2.5 fairly easily. I have a 9NPA+ Sli and may be able to help but need to know the specifics of your memory (as much info as you can provide).
m
imhungry
1,740
If you just bought the 3000+ it might be an E6...so it may not budge more at all.
What's the stepping on it?
I hit 2.8Ghz with +0.25 volts on my Opteron & Epox 9NPA+ Ultra.
Fallengod
5,908
19
Id bet he just doesnt know the correct bios settings. Im sure thats probably holding you back. Id recommend reading the guide on the forum. Ive never seen a 3000 venice that wasnt able to get over 2ghz.
