All Asus boards with bios's later than 1003 prevent the CPU from being in a total idle state. Also Asus boards have a problem displaying the real temps. I can certify that with my system, I have the Asus Thermistor and an independent sensor attached to the core and Asus temps are off by 7c all the time. This is a known problem with Asus boards and can be backed up at
www.a7vtroubleshooting.com
>I'm hitting around 50c sometimes 51c at near full load and 44c low load with a Gobalwin CAK-38
This is exactly what I'm getting during hot days
on my system but I removed the delta fan and put the fop32's YS fan on the WBK38, very quiet.
I'm running RC5 24/7 with a 1.33 at 13x100=1300 on an A7V without the cpcredit fix with a vcore of 1.65
Last evening (during hot weather) my case temp was 29.9c and cpu load was 51.9 (sensor)
This morning my case temp was 24.6 and cpu load was 44.7 (sensor)
Case temps and ambient temps are the same give or take 1c difference.
>the mobo BIOS reports that the CPU is running at 53 DEGREES C!
-7c = 46c so I agree with Mike your temps are fine, specially if you're acheiving this with a fop32. If you would have put an indipendent sensor and have a case temp of 24c you would probably see 40c to 44c whith what you have now. TheHorta I wouldn't touch anything if your getting this type of performance with a fop32, that is really good.
This is what I posted in another forum.
From my experience and from this forum, onboard temps really cannot be trusted. Different boards will display different temps, even different BIOS's may have a significant impact on accurate readings by as much as 15c or more and on top of that some boards may not even show accurate temps. The only true way is to put an separate and independent thermostat touching the core.
Overclockers.com had an excellent article on this, the best accurate and external temp they could achieve with an athlon with airflow was 36c. What one reads on ones board will be totally different on another with the exact same setup.
Take Asus for example, every bios starting with the 1004 had the HLT command disabled in the bios, this prevents the cpu from being in a total idle state, it's as if it's running at %75 load so unless you enable the HLT command in the bios your CPU will always run near load and so creating a temp closer to under load. Just in this example you cannot compare the Asus temps to other boards and even if you do have an external thermostat like the compu-nurse. However there are advantages to having the HLT command disabled, so you trade off higher temps for more performance.
What I'm saying is that every system is different, having lower temps on one system may not be the best, and having high temps on another system may also not be the best.
