QueBert
Haven't been all that impressed with the mATX cases I worked with in the past. Picked up this one from PC Club. Almost completly tool less. Maybe I'm weak but I couldn't get the thumb screws off by hand to get things started 🙂 You have to use a screw driver to mount the HD and optical drive too. The thing came apart pretty easy, thumb screws hold on the 5 1/4 bay, has stealth covers for the optical/floppy drive. Apperance is a personal perference, but I think the case has an elegant look, you can use it vertically or horizontally. It feels sturdy, only downside is the rear fan mount was pretty flimsly, if I move the case it falls off, dunno if this is how they come, or I just screwed it up (or got a bum case) Has a pretty nice blue led bar along the front, goes well with the black and silver. Also has room in the front for a 80mm fan, comes with 2 60mm's in the back. They don't push much air, but they don't seem to make much noise either. Only comes with a 200 watt PSU, but for a HTPC type setup you don't need nothing huge.
pluses
thumb screws
well built
well laid out
cost $50 bucks
can hold 3 HD's
comes apart easy
minuses
cramped (can't do much with mATX though)
back fan bracket falls off if you move the case, no matter how much I tried, I couldn't get it to really "snap" on the case.
could have used drive rails for the optical/HD
doesn't come with an 80mm fan for the front.
I ordered 2 more of these suckers after I was done building the first one. I didn't expect a whole lot for 50 bucks, and was really surprised.
pluses
thumb screws
well built
well laid out
cost $50 bucks
can hold 3 HD's
comes apart easy
minuses
