AT'ers gather round......help me fix this bad boy!
Jun 14, 2003
10,442
right im fixing up a computer for a friend as a return favour. he knows im not gonna be his personal tech, jus for the record
anyway this computer
some gigabyte VIA based mobo
Athlon XP 2400+
512 ram
new samsung IDE HD...spinpoint series.
MSI multi combo drive
and a generic 350watt PSU with 18v on the 12v rail
now
he managed to get it formatted, from what he said on the phone, but not any further.
ODD problem---- with the HDD plugged in IDE1 and into the power, and the DVD drive plugged into the power, but not into IDE2. it powers up, finds the HDD and then just waits....doesnt try search for an boot records or what ever
with the HDD plugged in and connected to IDE1, and the DVD powered and connected to IDE2, its a no show. both the DVD and HDD fail to power up and the computer tells me theres no pri master or slave
so theres definately enough juice to power them both, but once connected to ide 1 and ide 2 the both just die. what gives
Jun 14, 2003
10,442
Originally posted by: snoturtle
try a new cable on the dvd drive
i dont have a spare (will go have a dig) but i just started the system up with just the DVD connected up and it failed to come on
i swapped its IDE cable for the HDD and did the same again, and it powered up....so i just need to find a spare cable.
S
SlitheryDee
When you say fails to power up you mean no lights on the DVD drive and no HD spinup whatsoever? It doesn't sound like this is the problem but have you checked the master/slave/CS jumper settings on both drives?
PS: You probably have but sometimes the solution is so simple you just can believe it. ;)
Jun 14, 2003
10,442
snoturtle wins the prize, (dunno what prize, maybe a bear if i ever meet him) the IDE cable for the DVD was shot
changed it for one out of mine, runs now, had to manually tell the bios the drives were present tho, but its worked.
Jun 14, 2003
10,442
yeah id checked all those, an i meant no power at all, no spin up, no lights, no tray opening.
and yes the problem was super simple......replace IDE cable. cant believe how long ive spent
snoturtle
1,609
Glad it worked out for you :)
its always the smaller things that you look for last
so now I look at those first :p
