If you have 3x 100gb drives, the RAID controller should still recognize them independantly as 100 gb, then join them and report a 300 gb drive... I don't know though.
I don't think it would recognize any one single drive larger than 137gb, but I could be wrong. It might just be overall including all drives on the raid, or maybe the largest partition could be 137gb.
