ATA 100 and ATA 66 together
DDevine
I'm getting a new computer with an ATA 100 bus and drive, but i have an older ATA 66 drive that i'd like to hold on to. If I connect them on the same interface, I assume that the bus will have to come down to ATA 66 for both drives. Is that correct? Will it be automatic? Does the same thing happen if you put a ATA 66 or 100 on the same interface as a CDROM?
Dan
well, considering you can hook-up an ata/33 cd-rom and an ata/100 hd on the same ide channel, it should work also w/ an ata/66 hd... i could be wrong though...
Don't worry about the ATA66 bringing down the performance of the ATA100. Today hard drive can't use all of the bandwidth(?) of the ATA66 yet.
there isn't that much of real world performance difference between ata66 & ata100 so you should be fine to have both hdds on the same ide cable.
if the hdds are on a promise ata 100 controller,devices of different standards can be connected to the Ultra-100 without performance degredation, due to the independent programmable timing registers in the controller's design.
Basically,that means that having an ata 100 hdd on the same channel with a hardware device of different rating will not degrade the hdd's performance.
