Impressive. Will likely be out in early March, just after MWC. Samsung is holding a press conf 1 March. Intel's process tech lead is shrinking fast.
Come on, you're still saying this? At the very least, you should find your stance to be highly debatable, rather than continuing to obstinately present it as fact.
TSMC's 10nm isn't coming until 2017. Samsung's 10nm will show up sometime in 2016, but their specifications are much more lax. Intel's is likely to show up late 2016/early 2017, but will easily outperform their two closest competitors.
It's interesting that Qualcomm/Samsung/Apple/AMD stood still at 28 nm for so long, and now all of a sudden they are forging ahead to 14 nm, passing 20 nm quickly.
Samsung's 20nm was very late -- their 14nm came very early. Their quick abandonment of 20nm makes a lot of sense.
AMD is still up in the air. Nobody knows what they're doing; heck, even they don't know what they're doing.
Qualcomm's been using 20nm for about a year to some extent. They are going to be on that node for some time still.
Apple's been on 20nm for a year, and will likely be switching to Samsung's 14nm after Samsung's had their turn. So, Q2 perhaps, with products showing up this fall.
Just laying things out -- not necessarily disagreeing with you here. Adoption of 16/14nm should be very quick -- FinFETs are the biggest advancement in process tech since transistors were conceived.
