ComputerWizKid
How do I wire the power switch? I have 5 wires comeing out of it one of which is ground Blue Black White Brown Green with yellow stripe Thanks
That is an ATX power supply. 😛Originally posted by: JimPhelpsMI
Hi, Jumper the green lead to any black lead in the 20/24 pin connector from the PS. You can also use a switch. Jim
Originally posted by: Zepper
The PSU itself should have a switch wiring diagram on the label somewhere (but it may NOT be accurate - it has happened to me, so always trace the wiring to be sure!) : Most often I've found it to be:
- Black is HOT coming in from wall,
- White is neutral coming from wall,
- Blue is neutral going back to PS from switch,
- Brown is HOT going back to PS from switch.
The usual switch was a DPST 10 Amp push on-push off or rocker - the neutral wires conect to one pole (side) and the hot connect to the other pole - white and black across from each other and black and brown acoss from each other - IOW, white and black would go on the common (usually near the physical center position of the switch). Green is ground and usually has a ring or spade terminal on the end to go under a screw on the chassis somewhere near the swich (really can go wherever it reaches) .
coarse diagram of typical switch terminals
push-|-button switch shank.
------_|_
-----|----| (one end may have no terminals or not used if present)
Bk--|----|-W
Bn--|----|-Blu
Hope that looks correct on your screen.
.bh.
