UPDATE: HERE IT IS, DOWNLOAD NOW! (Just open, don't save, using FireFox and it should give you the dialogue to install... or use CLI install) Tested on 1.5.x and 2.x. Tremendous thanks to MrChad for writing it.
UPDATE 2: IE7 version here! Thanks UCJefe :thumbsup:
Test them here! 😉
Here's my idea for a very simple but useful Firefox extension for AT Forums:
Ever follow a link to an archived thread, which has its own links to other old threads that have since been archived, but none of the post content has ever been updated so those 2nd-level links are all broken? I would find it extremely useful to have a context menu option so that when you right-click a URL, you can choose "AT Forum Archive". All it would need to do is append the string "&arctab=y" to the URL of the target hyperlink and load (a more complex version might check for the presence of the string in the URL, and add it only if necessary, so you can just click away at any questionable link and not disturb a properly archived thread). Unless the thread was outright erased by the Mod Secret Police, this will make archive navigation MUCH easier.
Inspired by some frustration following old threads dug up from the OOTY nominations.
Any takers? I'd pledge $1 via paypal as the start of a prize pool to reward whoever can make this a reality, and encourage anyone else here who would find it useful to do the same (I'll list any additional in-thread names/pledge commitments below)... should be very simple for someone who knows how to write extensions... 🙂 Presumably this would be "A Good Thing"(TM) for users of any other FuseTalk-based forums to have available as well.
PLEDGES closed, thanks:
AStar617 - $1
Crono - $1
1) Unzip files
2) Move the script.js file anywhere you want
3) Edit the AT_archive.reg file to contain the path you just moved the script.js file to. Just replace the text "c:\\temp\\script.js" with your path and remember to double up your backslashes.
4) Double click .reg file to install
5) Restart IE or open up a new window
Test them here! 😉
AStar617 - $1
Crono - $1
