AT case with a ATX motherboard
22b99
33
Here is a newbie question that I need an answer for. Will an AT case allow for an ATX motherboard without any modifications.
Thanks in advance for any help.
buzzby
33
My understanding is that a AT MoBo will fit in a ATX case but NOT the other way around
Desmoquattro
Banned
Apr 28, 2001
622
yep he's right. you'll probably have problems finding the right holes for the ports and an AT power supply will not work with an ATX board...although you can purchase an adapter for an ATX power supply to be used on an AT board.
wolfsblood
330
Nope, just look at the AT case and then the ATX motherboard, and you will see that it will not fit
