Originally posted by: glenn1
Originally posted by: Zenmervolt
Originally posted by: dug777
I'd guess it was in the highest gear at the lowest speed the engine isn't lugging.
The winner.
For most cars it's between 35 and 45 mph. While the 55 mph speed limit was set to reduce the amount of fuel we used, it was chosen as a balance between speed and fuel consumption, not as the optimal speed for mileage. I can get mid to high 30's in terms of mileage from my '98 S70 at ~40 mph on level ground. At 55-60 I'll get 28mpg. Most cars show similar benefits at 35-45mph.
ZV
Wouldn't the speed to achieve optimal mileage depend on the coefficient of drag for the car? IIRC, wind resistance increases exponentially with speed.
Drag increases with the square of speed, but that's relative. Yes, a car will get better mileage overall with better aerodynamics, but it achieves that benefit at all speeds, though the benefit is more pronounced at higher speeds as you note, but it will still do better at lower speeds. Reducing drag is a means of reducing the penalty for going faster; it cannot negate the penalty, but it can reduce it, sometimes significantly. The best mileage is still achieved at the lowest possible speed in the top gear while avoiding lugging the engine.
Drag coefficient is actually not a measure of overall drag though. Drag coefficient is the multiplication factor of the vehicle's frontal area that is needed to arrive at the total overall drag. For example, a perfectly accurate 1/10 scale model of a car has exactly the same drag coefficient as the full-size car, but the 1/10 scale model experiences less overall drag because it has less frontal area. Drag coefficient is useful for measuring the aerodynamic efficiency of a shape, but it doesn't take into account the size of that shape. In most cases, frontal area plays a greater role in total drag than the drag coefficient, though of course a truly bad drag coefficient can become the key driver.
For example, a 1994 Volvo 850 Turbo Station Wagon has a drag coefficient of 0.32, while my 951 (aka 944 Turbo) has a drag coefficient of 0.33. However, because the 951 has roughly 2.5 square foot less frontal area, the overall drag of the 951 is lower than the drag on the Volvo wagon (drag area of 7.16 sqft for the Volvo versus 6.56 sqft for the 951).
ZV
