Asustek A8N Premium question
Usin Asus Probe, you are able to obtain CPU and Mobo temperatures, NOT the "chipset" temperature. I know it runs quite hot, but as long as you have decent air flow over the motherboard you are ok. Make sure your chipset heatsink fan is spinning though, or simply upgrade to a zalman if you have good airflow.
My A8N Sli Premium reports mobo temp from 36 to 44 depending on the room temperature.
That is very cold. Mine has been doing nothing for a while:
CPU: 41
MB: 39
Still need to re-arrange case airflow.
yeah mine mobo temp ususally stays constant or maybe go up by a couple degrees after gaming. During summer it was usually slightly above 40, now at night is drops to mid 30s.
