AsusA7V Ahlon Overclocking need help with bios problem
skewett
I have just set the L1 bridges on an Athlon 800. When I reboot and exit to bios I only see CPU Frequency Setting and a DRAM Frequency. A friends identical machine shows a CPU Clock Multiplier as well. Interestingly his manual shows CPU Clock multiplier listed in the bios on page 58. My manual does not show this as an option.
I have altered the CPU frequency and CPUZ indicates that my processor is now running at 880MHz.
Have I successfully clocked the chip.
Why do I not get the Multiplier option in the bios. Both my bios and my friends are the same version (1005b).
Any help would be appreciated.
GasX
29,033
My A7V doesn't have a bios way to change the multiplier either. There are jumbers on the board that are very easy to set.
mechBgon
Oct 31, 1999
30,699
You and your friend might have different revisions of the motherboard itself.
skewett
Thanks Mwilding for the advice but I think I have a version of the mboard which allows jumper free settings or JEN Mode. My Mobo is set to allow this bios updating but I still don't have the option of setting the CPU Multiplier.
I'm really close to cleaning off and re doing the Links on L1.
Any last minute thoughts
Jim
