I purchased this laptop a few days ago, so I would share some impressions and benchmarks. The Zephyrus G GA502 (GA502DU-BR7N6) I purchased from Best Buy has:
AMD's new 35W Ryzen 7 3750H APU
Geforce GTX 1660Ti Mobile-Q w 6 GB GDDR6
120 Hz vIPS LCD
512 GB Intel 660p M.2 NVMe SSD
Realtek 8821 CW Wireless LAN 802.11 AC 1x1
Realtek PCIe Gigabit NIC
Realtek Audio
2 x 8 GB DDR4-2666 SDRAM (One shows as Samsung Part # M471A1K43DB1-CTD 17CL) Specs indicate it can be expanded to 32 GB, but I don't know if one is soldered on or not.
76Wh 4-cell litium ion battery
Realtek Bluetooth 5.0
1 x USB 3.1 Gen 2 Type-C w DisplayPort 1.4
3 x USB 3.1 Gen 1 Type-A
1 x HDMI 2.0b
1 x 3.5 mm audio combo jack
1 x Kensington lock
180W AC adapter
2.1 kg / 4.63 lbs
https://www.asus.com/us/Laptops/ROG-Zephyrus-G-GA502/
I like the fans on this laptop. It sound like a strong breeze blowing under load and not loud like most laptop fans.
It's a light laptop, which was one of the reasons I went with this laptop.
The screen looks nice and has good viewing angles
New Ryzen 7 APU, so less Spectre/Meltdown issues
New 1660Ti video so new generation of video performance
76Wh battery suggests long battery life, unlike Asus' Tuf 505 DU which only has a 48 Wh battery. The battery capacity is larger than many other gaming laptops as well.
OK:
The speakers are downward firing and have decent volume, but I do wish it were front facing.
No camera. No one seems to put a good camera on a laptop, so I'm ok with not having one.
Dislikes:
The Intel 660p SSD performance can be terrible if you have Windows 10 System Protection enabled, but with System Protection disabled, it does perform well. Here are the times to unzip the 500 MB blender benchmark:
Intel 660p with System Protection On: 17 min 30s
Intel 660p with System Protection Off: 2 min 32s
My Ryzen 5 2500U laptop with a 500 GB SATA Samsung 860 EVO w System Protection ON: 3 min 54 sec
My Ryzen 5 2500U laptop with a 500 GB SATA Samsung 860 EVO w System Protection Off: 3 min 30 sec
Here's a link to the Intel SSD Toolbox, which will help to restore some of the performance of the SSD if it should start slowing down. The utility recommends running the SSD Optimizer once a week.
https://downloadcenter.intel.com/download/28674/Intel-Solid-State-Drive-Toolbox
(I listed the 660p as a dislike because I spent a few days trying to figure out performance issues when I had Nivida shader caching to disk enabled.)
The chiclet keyboard, while serviceable, isn't my preferred keyboard type for a gaming laptop. I also wish any gaming laptop had a spill proof keyboard.
Driver support for Nvidia Mobile-Q video cards. It seems you have to use the manufacturer drivers if you want the APU and 1660Ti to cooperate peacefully, but unfortunately, laptop companies don't update their drivers as often as AMD and Nvidia releases new drivers. I experienced lower performance with testing the APU compared to the Ryzen 5 2500U, so I removed the AMD/Nvidia Optimus drivers and went with AMD's 19.4.3 drivers and got better results. After I was done testing the APU, I reinstalled Asus' drivers for both.
So, on to some benchmark results. I also included numbers from my Lenovo Ryzen 5 2500U laptop and my Ryzen 5 2400G desktop.
Video Driver
Ryzen 5 2500U - Radeon 19.4.3
Ryzen 5 2400G - Radeon 19.4.3
Ryzen 7 3750H Integrated - 19.4.3 (I did this so people have an idea how the 3750H only laptops performs in general)
Ryzen 7 3750H 1660Ti - Radeon - 25.20.14132.2002 (3/7/2019) / Nvidia - 25.21.14.1971 (3/18/2019) (419.71)
Cinebench R20 - Multi
Ryzen 7 3750H - 1831 cb
Ryzen 5 2500U - 1366 cb
Ryzen 5 2400G - 1793 cb
Cinebench R10 - Single
Ryzen 7 3750H - 402 cb
Ryzen 5 2500U - 356 cb
Ryzen 5 2400G - 388 cb
Firestrike
Ryzen 7 3750H Integrated - 2987
Ryzen 7 3750H 1660 Ti - 4433
Ryzen 5 2500U Integrated - 2462
Ryzen 5 2400G Integrated - 3160
Timespy
Ryzen 7 3750H Integrated - 1096
Ryzen 7 3750H 1660 Ti - 4679
Ryzen 5 2500U Integrated - 867
Ryzen 5 2400G Integrated - 1186
Skydiver
Ryzen 7 3750H Integrated - 10041
Ryzen 7 3750H 1660 Ti - 4399 (I restested multiple times and uninstalled and reinstalled drivers, but for some reason, this has terrible results. Will restest if I replace the SSD)
**After resolving the issue with the Intel 660p, here's the new score for the 1660Ti: 22816
Ryzen 5 2500U Integrated - 8379
Ryzen 5 2400G Integrated - 11051
Unigine Heaven (DX11 / Med Quality / Tess - Dis / Stereo 3D - Dis / AA - Off)
Ryzen 7 3750H Integrated - 850 (33.7 FPS - 18.1 Min - 65.1 Max)
Ryzen 7 3750H 1660 Ti - 3148 (125.0 FPS - 31.4 Min - 175.2 Max)
Ryzen 5 2500U Integrated - 690 (27.4 FPS - 14 Min - 50.3 Max)
Ryzen 5 2400G Integrated - 915 (36.3 FPS - 21.0 Min - 74.6 Max)
PCMark
Ryzen 7 3750H - 4390 (Essentials - 7828 / Productivity - 6328 / Digital Content Creation - 4635)
Ryzen 5 2500U - 3338 (Essentials - 6736 / Productivity - 4699 / Digital Content Creation - 3189)
Ryzen 5 2400G - 4122 (Essentials - 7660 / Productivity - 6191 / Digital Content Creation - 4009)
I wanted to check power levels, but I can't find my Kill-A-Watt meter, so if I pick one up again, I'll post some Furmark scores. I also plan on doing a movie/streaming marathon at some point to see how long the battery lasts.
Also, note that the Zephyrus G on Newegg and Amazon for $1099 is the GA502DU-PB73 model, which just has the 60 Hz screen.
120 Hz vIPS LCD
Realtek Audio
1 x HDMI 2.0b
1 x Kensington lock
180W AC adapter
2.1 kg / 4.63 lbs
OK:
Dislikes:
Video Driver
Firestrike
Timespy
Skydiver
PCMark
