- Apr 7, 2011
- 43
- 0
- 0
I am using a Asus Z-87A motherboard with an corsair H100i.
I hooked up two radiator fans and two case fans to the h100i with the included cables. I also plugged in the mini usb into a usb header onto the motherboard. I also connected it into the cpu fan header.
I've also downloaded all the drivers required for the motherboard.
When I go into the BIOS, speedfan, corsair link, asus fan xpert it only shows up as one fan.
I'm using 2 noctua NF-F12 which have 4 pin connectors and 2 case fans from the Fractal design define R4 which have 3 pin connectors. I connected them to the h100i. And the h100i is connected to the motherboard.
How do I get it to differentiate the fans? Please help!
Thanks in advanced.
Thanks in advanced.
