Specs:
Asus Z68-V PRO GEN3
2500k
gtx 680
HX750
2x4gb gskill ddr3-1600
System has been working fine and I haven't had any recent issues. I turned the machine on and I'm not getting any video signal out of the blue. Fans are all spinning up, I have cleared the CMOS and used the jumper as well.
I wasn't making any progress so I pulled all the hardware out of the case and tried a minimal boot. The system will will post with video maybe 1 out of 10 times booting up. Otherwise I get a solid vga led and no video.
I've been digging around and haven't found a solution. Seems that some people were reporting that it was the motherboard gone bad?
Any help would be great. I don't think I'm leaving anything out while testing for a solution.
If this would be a motherboard issue, would I be better off getting a different mb (Z77) instead of the same exact board?
Asus Z68-V PRO GEN3
2500k
gtx 680
HX750
