ASUS V7100/TV-out + AOpen AX6BC, will not work properly
ONN
ASUS V7100 and my AOpen AX6BC, motherbord, is not working properly:
The situation is, after a moment, then the computer works, mostly in the weeb, the mouse will start too move very slow, and the opdate of weeb-pages is were pure, my quistion is what can the problem be?....is it the AGP card, the motherboard and the power supply.
This AGP card requires large 3.3V current from power supply, which as I know, most of the ATX power supply on the market can not support it. Actually, I found this card can only work with ASUS motherboard, which does not use standard 3.3V ATX power, instead, there is a special 3.3V regulator on the motherboard and the voltage has been adjusted to around 3.45V. You have my gratetude, if you have the solution,
Many thanks Phuwanat from Thailand.
;):confused:
