asus sli premium ram timing help
bennny
45
Hi I have a asus sli premium setup, with a wini 3200 64 proc, dual 6600's, 2x512 hyperX 3200, and a raid 0 raptor setup 500 watt thermaltake psu. At the moment im running 250 htt x4 ht, with a multiplier of 10 @ 1.55v. The ram native timings are 2-2-2-5, but im running them at 2-3-3-8 1t @ 2.6v, and seem to be stable, can play cs:s for hours on end and no problems, but prime95 always halts after about 34 minutes, with a .5 instead of a .4 calculation. Any suggestions on what timings I should relax, or areas where I can tighten the timings at all.
Thanks!
Megatomic
20,127
Try 2.5-3-3-8. Are you running with a memory divider? If not, you may need to set Memclock Index to DDR333. You'll still have a DDR speed of 208MHz, but your stability may be MUCH improved.
bennny
45
Yeah, im running with a divider, thanks for the tip, ill try that. Any suggestions on what other timings to relax, or tighten, I am on a quest for 2700 mhz. thanks!
Megatomic
20,127
CAS is the likeliest culprit for you right now. If you need to try something else, try lowering Trcd to 4.
