- Sep 15, 2009
- 321
- 84
- 101
The highend of highends. The 16 threads in desktop with DDR4, crazy multithread speed, awesome power consumption for this performance. This is Haswell-E and X99. And a bit more with the best of the best - Rampage V Extreme.
Black Edtion, sound of future?
64 GB of Memory DDR4. 2400 MHz XMP cl15.
1. - Before all descriptions, benchmarks etc. You need something knowledge of theory.
I will write only most interesting things from my side, because all about theory you can easily find at http://rog.asus.com/?s=x99&submit.x=0&submit.y=0.
OC socket and DRAM support. X99 is new in DDR4 support. DDR4 are working by Jedec at 1.2V 2133 MHz. The latencies are in theory a bit higher, but with reworked IMC in Haswell-E doesnt matter because are very quick and good OC able also. Rampage is uspport 3300+ MHz DRAM clocks! Wow. We will see, how good are my 2400 XMP HyperX
. The red slots are your first Quadchannel. The black are secondary priority slots...
OC socket is more pins in LGA. The CPU has more pads than standart LGA2011-v3 socket. So, why can not try more conection as servers Haswell-EP?
More pins in Asus MBs X99 are good for better stability in high OC. Example if your CPU could run at 1.35V with some LLC, there are overvoltages jumps and drops. You know the most straight flatline is the best for stability. So LLC helping in this case a bit (no drops, no crahs in load
). The next pins could be electrically conected to IMC of CPU. The biggest differencies with OC socket I have seen in OC of DRAMs and Cache. With OC socket you can get cache around 4 GHz or more at good aircooling!
PCie slots 3.0 are from CPU directly. But not all X99 CPUs have the same number of PCIe lines
. I7-5960X+5930K have awesome 40 lines and the cheapest one 5820K-i7 has "only" 28 lines. So the red slots are with SLI/Crossfire different by CPus inside
. 5820K can use 3 GPUs in 16-8-8. The 5930K+5960X 4x GPUs as 16-8-8-8.
The black slot is PCIe 2.0 from PCH...
