I'm not quite sure if I should have posted this in the Motherboard section in stead, but here goes.
On recent ASUS motherboards the Q-Fan feature can be set to two modes. The traditional one, where the speed of the CPU cooler fan is set by changing the voltage of the fan. The other mode is to let PWM control the fan speed.
Needless to say that the latter mode will only function with a PWM-controlled fan.
My question is this: can a PWM-controlled fan still be controlled/slowed by reducing the voltage as used by the traditional means of fan-control? Or would that damage a PWM-controlled fan?
I'd really appreciate some input on this, so thanks in advance!
