I have an Asus A7M266 motherboard with a 1.33GHz Athlon. It's running great--however, I'm having a bit of problem with the Asus 2 Probe utility. I keep it running in the background when Win2K starts up. When I installed the software, I accepted the default settings for voltage monitoring, which was +/- 10% of the set voltage (12.0v, 5v, and 3.3v--and the VCore).
My problem is that every so often, when I'm using the computer--and not necessarily running a full CPU load--the voltage meter alarm would go off. The 3.3v meter is fluctuating by more than 10%--usually by maybe another 1 to 2 percent, and never for more than a couple of seconds.
So, my questions are: 1) does this indicate that there is a serious problem with the voltage that's coming out of the power supply? The case has an AMD-approved PowerMax 300W supply; 2) if that's not the case, what can I do to fix the problem? Obviously, I can set the alarm threshold to 12 or 13 percent. But it seems strange that this is happening with the 3.3volt meter only--the other three are all running well within the alarm parameters.
Thanks in advance for any help, guys.
Hyun.
Hyun.
