- Jun 10, 2012
- 66
- 0
- 0
My previous ASROCK P67 Extreme4 B3 did not survive a thunderstorm and the death of a router (lightning hits telephone cables, cables carry to router, router fries, my computer is pinned as the first LAN line, my mobo fries via in-built LAN card). Thankfully no other hardware casualties
Now, I'm having a bit of a hard time doing a proper OC on my new board (latest BIOS installed). I can get what I had before, easily (4.6Ghz), but only through the OS interface and still, I'm concerned about a few things.
One, I expected to squeeze a bit more out of the CPU with this board (more powerful section, better parts, generally a better OC board and chipset). Theoretically, the TurboV thingie takes me even to 5Ghz in the Extreme settings, but the voltages it wants reach almost 1.5v and temps follow. Nu-uh. The "fast" version goes to a meager 4.3Ghz. Since I play BF3 and ARMA2, I need the most CPU power I can get. I'd be happy with a fully stable, non-ridiculous voltages, @4.8Ghz, really.
However, I apparently can't find the proper options in the BIOS. The CPU multiplier is there, but it's described as a maximum for the autotweaking, not a "proper" multiplier. I can up the BLCK manually, but the rest seems to handle itself in auto mode only? When I OC through the OS, apparently I can make the CPU to just go BLCK 100, x4.6, but despite LLC being turned off, the 1.325 voltage goes as high as 1.45v, while with Medium LLC, a 1.3v setting becomes 1.4v under load (!).
I don't know why the voltages get out of hand like that. HALP?
