I'm posting this in the motherboard forum because I suspect it's a motherboard problem.
I just bought a USB3.0 portable hard disk. When I plug it into the back-panel USB3.0 ports (that are directly stuck to the motherboard), everything works fine.
But when I plug it into the front panel USB3.0 ports, the hard disk disconnects at random intervals every 30-40 seconds, then instantly reconnects (and windows throws up the "autorun" dialog box). I built this PC myself a month ago, and this is my first USB3.0 device. The case is a Corsair Carbide 300R. The front USB3.0 plugs (two of them) connect to the motherboard via a 20-pin USB3 header (like this).
Here's the wierd thing. If I use a USB2.0 cable and plug the hard disk into the front panel USB3.0, it works fine (albeit at USB2.0 speed) and doesn't spontaneously disconnect. Also, all USB2.0 peripherals I plug into these same front ports have been working fine all month.
Any ideas?
P.S. I tried running a disk benchmark while connected to the front usb3 port, and the speed was 110MB/s - so it is in fact getting USB3 speeds before it randomly disconnects...
Any ideas?
