- May 19, 2011
- 20,007
- 14,346
- 136
It's not the same board as the one in this thread, in case anyone was wondering
https://forums.anandtech.com/thread...ter-switch-on-then-comes-on-properly.2552643/
Switch computer on, fans spin up, within a second they lose power. About a second later it repeats endlessly (well, I've never let it go beyond 6 times IIRC).
I've tried:
Disconnecting everything except what is strictly speaking necessary to boot (CPU, RAM, board, power, DVI, and I've tried it without DVI)
Another PSU
Removing RAM
Trying RAM in another socket including the one approved for single module use.
Clear CMOS via jumper
Clear CMOS by battery removal
Another CPU (what the heck, I had one spare) - CPU socket looked OK
Using MemOK button
Using another power switch
Replaced BIOS chip
Probably other stuff too, I can't remember. I've run out of things to try.
The only variation in behaviour was when removing RAM / clearing CMOS - the delay before it switched off was about a second longer.
A bit of history: The computer is a few years old (i3-3225, 4GB DDR3-1333), no problems until this:I saw this computer a few months ago whereby occasionally it would freeze or the screen go black and non-responsive, intermittent issue. As the issue appeared to go away after driver updates (except when running memtest 7.4), I thought that maybe the memtest thing was a quirk related to this board and as it passed other memory-type tests, but the intermittent issue started back up again after a few days of use. It then started to happen more often. It wouldn't necessarily fail under load either.
I suspect this board is faulty. Any other ideas before I get a replacement board for it? As I've had another board of the same model do something similar (but is still in a usable though quirky state), I'm wondering if it's a failing common to this model so I'm thinking of going for the H77 version of this board.
I've tried:
Another PSU
Removing RAM
Using MemOK button
Replaced BIOS chip
