Please see post #17 for current state of this thread.
i7-2600K to be exact
I'm using water cooling. Please let's stick with this in this thread. A debate water vs air is not what I'm after.
This CPU stays @room temps all the time, but when I put any load on just one core, it immediately jumps to >60°C. This makes it extremely hard to control fans on the radiators. I have no idea how much wattage the computer is actually consuming and am forced to run the fans at 100% (since 60°C is hot).
But actually, this is not the case: if only one core is loaded, the fans spin up immediately despite the fact that this is only for a few seconds at a time (app compilation, for example).
I have been watching other sensors and none really convey the true state of my computer at any given moment. Perhaps chasis temp (some sensor on the MB I suppose) is the most accurate, but that only moves a few degrees no matter what happens. As such it cannot be used for this purpouse.
What I'd really need is a sensor that would see water temps, but that doesn't seem to really be available.
The only other alternative I see are those automatic fan controllers that come with their own sensors. I could just stick those sensors into the radiator and hopefully set all the cooling / pump voltage based on that?
What do you guys use?
