- Mar 11, 2014
- 2
- 0
- 0
While playing Titanfall last night my computer experienced a BSOD for the first time in months. It reset itself and came back on like normal. I turned it off properly and went to bed. Today, I can't get it to POST. The VGA_LED light comes on during boot and stays on. Here's what I've tried:
and nothing has worked. I did get a CMOS clear to take one time, and it did finally turn on through the onboard video (my graphics card was not in the machine at the time). So I went into the advanced BIOS settings to set everything back the way I had it and accidentally entered the EZ flash utility. So I exited the utility and the computer hung for a really long time. So I had no choice but to cut the power and try again. Now I can't get it to boot even though I've tried clearing the CMOS a dozen or so times. It should be noted that I did NOT attempt a BIOS flash in the utility, I just went to its screen and then exited.
The VGA_LED lights up and I can't get it to use the onboard video now. Is there a way to force the onboard? Right now I'm trying a CMOS reset again by leaving the battery out for an hour or so. I'll post here if that does anything.
Any help? Thanks
- -Reseating the video card
- -Putting the video card in a different PCI slot
- -Plugging in the onboard vga to my monitor/using no video card
- -clearing the CMOS
Any help? Thanks
