Asus P8P67 Pro Rev 3.1 Red blinking LED on VGA, CPU & DRAM
pc4gary
Just build my first PC but it will not enter the [COLOR=blue !important][FONT=inherit !important][COLOR=blue !important][FONT=inherit !important]BIOs[/FONT][/FONT][/COLOR][/COLOR]. Monitor don't even have signal through both HDMI and DVI. Everything seems to run fine but these 3 blinking red LEDs. The first is VGA, second is CPU and third is DRAM led. Is this a faulty motherboard or did I connect something wrong? Please give input if you can. Thank you!
Here are links to videos of the problem
http://www.youtube.com/watch?v=Fsx8BN09Tik
http://www.youtube.com/watch?v=eHdikMUQKTQ
http://www.youtube.com/watch?v=BDr [...] ideo_title
Here are the pictures
http://www.youtube.com/watch?v=QqoAHuE_j-Y
Here is my specifications
CORSAIR Professional Series HX750 (CMPSU-750HX) 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS SILVER Certified ...
LG Black Internal 12X Super Multi Blue with 3D Playback Blu-ray Disc Rewriter SATA WH12LS38 LightScribe Support - OEM
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop [COLOR=blue !important][FONT=inherit !important][COLOR=blue !important][FONT=inherit !important]Processor[/FONT][/FONT][/COLOR][/COLOR] Intel HD Graphics 3000 ...
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel ...
SilverStone SDP08 3.5" to 2 x 2.5" Bay Converter
Crucial M4 CT256M4SSD2 2.5" 256GB SATA III MLC Internal Solid State Drive (SSD)
ASUS P8P67 PRO (REV 3.1) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel
[COLOR=blue !important][FONT=inherit !important][COLOR=blue !important][FONT=inherit !important]Motherboard[/FONT][/FONT][/COLOR][/COLOR]
EVGA SuperClocked 012-P3-1573-AR GeForce GTX 570 HD w/Display-Port (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
COOLER MASTER HAF 932 Advanced RC-932-KKN5-GP
1 ASUS 23" [COLOR=blue !important][FONT=inherit !important][COLOR=blue !important][FONT=inherit !important]Widescreen[/FONT][/FONT][/COLOR][/COLOR] 3D LCD Monitor with NVIDIA 3D Vision Kit, Black (VG236H)
Thats normal check sequence of bios count down, you just dont want any LED to stay on.
Del key to get in bios right?
What happens when you insert Win 7 DVD during boot, reboot PC after its in??
Loosen 4 nuts on CM 212 until just bare finger tight - no socket use
Make sure you used 5/16 body length brass mobo standoffs, not 1/4"
I dont know why but a lot of these mobo need a full cmos clear to get going............
shut down
put PSU rocker to 0
push in case "ON" button for count of ten till caps discharged
Unplug PSU
Move cmos jumper to #2-3 pins
take out battery
Wait min 30 minutes, overnight much better
reverse proceedure
