I recently picked up the following package from NewEgg:
Asus P5WDG2 WS Pro mb
Intel E6600
Crucial 2x1g PC2-6400 Ballistix ram
BFG 8800 GTS oc @ 640mb (just 1)
(Salvaged some parts from my old system
Viewsonic VX2025wm LCD
Windows XP Home edition (32 bit with sp2)
OCZ 520w Powerstream PS
CoolerMaster Stacker case
36g Raptor (as Boot disk 1)
40g IDE WD (as Boot disk2)
Got it all together but I can't seem to get the memory running at the 6400. Wants to not post and go back to 5300. Other than this and the boot sequence all settings are default factory setting on the mb. I'll come back to this a little later.
The graphics card is recognizing VGA monitors with a VGA/Digital adapter but wont recognize a straight digital cable...no signal to the monitor. This doesn't seem to matter what port I'm using on the card or what PCIe slot the card is set into.
After trying it seems everything imaginable, I still cant get the signal to work and note that everytime I moved or disconnected the card or the cable going to the card I usually had to clear CMOS and reset the BIOS after default to get it to boot. I've done it so many times now that after clearing CMOS and resetting the settings (ie. boot disk sequence) sometimes I just get a screen that says "WAIT..." (I've waited up to 30 mins for this screen to clear but it never does). I don't have a good feeling about that.
The LCD works on my old 6800ultra digital to digital just fine but nothing with the 8800.
I had the mb set on "Performance" but now it doesn't want to post even with the memory running at 4600 so now its up and running with the mb set to "Stable" but my cpu mhz is down to 1600mhz.
I talked to Crucials tech support and they told me I can get 6400 out of the RAM if I up the voltage to it to 2.2v. I did and it posted ok but then windows crashed on booting and I had to clear CMOS in order to be able to post again...
This should be a rocking system even stock with no oc but I am having an issue getting even stock speeds out of it, any ideas?
I also wanna know if you think the ram issue is in any way tied to the graphics card failure to recognize a digital signal. I talked to BFG and they said that because its a hardware issue I'll probably need to RMA the card back to NewEgg...
I'm also wondering if the PS might be an issue. When I talked to the Crucial and BFG techs they said that the PS should be more than fine with the set up I have if I'm just running at stock speeds but idk...
Is there any chance someone else thats running the same config with this board, cpu and RAM can post there POST settings and voltages?
Its been a week now of being on the phone with techs researching sites, and installing and removing things to the MB after waiting the 5-10 secs after clearing the CMOS jumper...any help would be greatly appreciated.
Intel E6600
