Motherboard temperature hovers around cpu temperature and reaches 40C for idle and 50C for 100%. CPU varies from 40C idle to 70C at 100% load (prime test).
Also at some point the CPU temp sensor reports 125C but all the cores are only at 60C.
This was really troubling, the CPU did not shutdown so somehow the MB sensor freaked out?
First of all the motherboard temperatures seem to be high considering CPU is at the same level for idle. Is this because of MB temp sensor placement and the GPU I have ?. Radeon HD 4850 runs hot usually around 60C to 80C.
I have not done any overclocking infact speedstep is enabled and having intel stock heatsink for now. My case is Lian Li PC-7B plus II. It has two 120mm fans for intake and exhaust.
This is my first build and I am planning to overclock the CPU using a lapped Arctic Cooling Freezer 7 Pro. Do you guys think I have to work on my MB temps first before heading on to overclocking?.
Speedfan CPU temp screenshot
Any input is helpful.
