ASUS P5A and ATI RADEON 7000 PCI W2K issues
THEWIORACLE
10
Having trouble keeping new Radeon 7000 PCI 64MB video card working in Windows 2000 prof. It either locks up in a few minutes or causes monitor to go to sleep during bootup. ASUS P5A Super7 ATX motherboard. Newest BIOs 1010 Beta 1. It only works if I have "Hardware Acceleration" set to none in Windows. As soon as I turn acceleration on by moving the slider button...my monitor will go into sleep mode. Monitor is Mitsubishi Diamond Pro 21FS. My original BIOS that I started with was a 1009 Beta BIOS - I have been running with it for 2 years with a older ATI ALL-IN-WONDER PRO PCI Card. I used the original driver that came with the ATI CD and downloaded ATI's newest RADEON 7000 driver. This is a PCI video card and not an AGP card. Running a AMD K6-3 400 with ALI Aladdin V chipset and newer 300watt ATX Power Supply - AMD approved.
GonzoDaGr8
2,183
Do you have AGP "turbo" mode enabled in BIOS? If so, try disabling it. I remember this being a problem for RAGE-chipped boards a while ago.
THEWIORACLE
10
Except this isn't a AGP vedeo card, it's a PCI card. AGP TURBO setting should not apply, since it's not in the AGP slot. I spent 2 weeks trying to get a Creative Labs Annialator Pro AGP card to work. I gave up on AGP for this P5A motherboard long ago.
GonzoDaGr8
2,183
<< Except this isn't a AGP vedeo card, it's a PCI card. AGP TURBO setting should not apply, since it's not in the AGP slot. I spent 2 weeks trying to get a Creative Labs Annialator Pro AGP card to work. I gave up on AGP for this P5A motherboard long ago. >>
D'oh!! that's what I get for reading too fast...Sorry
THEWIORACLE
10
Got the PCI-based ATI Radeon 7000 to work. It was either PCI Latency Timer (0, I changed to 25) or Frame Buffer Posted Write (disable). It works great now.
