It is my understanding that the P4G8X and GA-8INXP deliver 4.2GB/s bandwidth which is balanced with the 533MHz FSB with dual-DDR226 memory. Is it necessary to buy 4-1GB modules of DDR266 to achieve a bandwidth of 4.2GB/s with the P4G8X? Can we use 2-512MB DDR266 modules and still achieve a bandwidth of 4.2GB/s? Please elaborate on any configurations that would achieve a bandwidth of 4.2GB/s. Thanks!
In my first attempt to build a PC by myself, I have had to rely on what I have been told by the manufacturers (ASUS, GIGABYTE, Intel, ATI, Plextor, Lite-On, Maxtor, etc.). After several weeks of combing the Web for info about a comparison between the P4T533 and the P4G8X I have come up with a few redundantly supported recommendations regarding compatibility and performance issues. Here is what I have been told so far - take it for what it is worth:
Recommended components:
Memory: Corsair, Kingston, or Samsung DDR266 CL2.5 512MB (double-side) - Recommended by ASUS
Video Card: As far as the manufacturers (ASUS, ATI, nVidia, know, every 8X and 4X tested with this motherboard has worked with few (easily remedied) or no complications (sounds like famous last words to me, but that is the score as I was told).
Hard Drive(s): Maxtor Ultra Series Hard Drive Kit (7200 RPM, 8MB Cache, ATA-133) has been recommended as one of the best per $ spent. There are only 4 ATA connections available on the P4G8X (2 S-ATA with parallel to serial converter and 2 UDMA ATA 100/66). This means that you can only have 2 hard drives connected in RAID 0 or RAID 1 (not 0+1), your CD-RW connected to one of the ATA-100 ports, and your DVD-ROM connected to the last ATA-100 port, but there is no way to achieve RAID 0+1 on the P4G8X...right? There are six available on the GA-8INXP (2 S-ATA with parallel to serial converter, 2 UDMA ATA 133/100/66 and 2 UDMA ATA 100/66). Additional S-ATA or ATA-133 RAID controllers can later be added to any of the 5 PCI slots on the P4G8X, however transfer speeds are limited to 133 MB/s by the PCI bus and parallel to serial conversion of the Silicon Image 3112A controller. Therefore, we should not expect to swap out our ATA-133 drives for true S-ATA 150 drives and achieve 150MB/s transfers without RAID 0 More info on today's RAID controllers at Tom's Hardware Guide
Once again, guys, I am just starting into this hobby, so please correct me if any of this information is inaccurate. Thanks! Here is my proposed system:
Processor: P4 3.06GHz HT 533MHz FSB (balanced with dual-DDR266 memory?)
CPU Fan: I can't find any for this processor. Know of any? Please suggest!
Motherboard: P4G8X or GA-8INXP
Case: Kingwin KT-436BK-WM (5 80mm fans enough for overclocking?)
Power Supply: Enermax EG651P-VE FMA
Memory: 2GB Samsung 1GB DDR266 PC2100 184 DIMM CAS2/2.5 Registered ECC (model# M381L2923MTL)
Memory Heat Spreaders: Please suggest!!! Do I need them for overclocking? Yeah, I am really that dumb!
Video Card: ATI All-in-Wonder Radeon 9700 Pro
Audio Card: SoundBlaster Audigy 2 Platinum
Hard Drives: 2x 80GB Maxtor DiamondMax Plus 9 in RAID 0...I guess. Is this "safe"? What happens when I reformat?
CD-R/RW: PlexWriter 48/24/48A E-IDE
DVD-ROM: Lite-On LTD-163 - Please suggest!
