I've read a few posts indicating that certain mobos do not accurately report cpu temperatures. I'm using an Asus P4G8X, and both Asus Probe and MBM5 indicate the same CPU and MOBO temperatures. Should these figures be accurate?
I think MBM5 reports the CPU temps based on the ASUS probe. If you want to be sure, get something like a DigiDoc or a Hardcano and test the temperatures.
