So I finally get my system all put together...install 32-bit vista and start to install the drivers. (at this point vista is fully installed) The motherboard comes with ASUS InstAll wizard. I start installing and the computer has to reboot. Then the problems start. The system will not recognize the hard drive. In BIOS, during POST...nothing. So I clear the CMOS and start over. Sometimes it recognizes the HDD, other times nothing. And when it does recognize the HDD, I'm prompted to install vista again...and when I go through the install, vista does not recognize the HDD. the HDD is spining up.
So I changed out the HDD to my old 74gb Raptor and xp boots up...so I start to install the drivers and now it won't boot up...says I'm missing a windows 32.dll.
Is this something that is RMA on the motherboard? or can I clear out the BOIS somehow to start over? please help. here's my system:
motherboard: ASUS maximus extreme
CPU: QX6850
RAM: Cellshock DDR3-1800
HDD: WD Cavier SE16 750gb
videocard: eVGA 8800gtx superclocked
thanks in advance
CPU: QX6850
thanks in advance
