Asus M5A97 Pro usb problem.
Shashmahal
Hello. Since i changed my MB from Asrock 970 Extreme 3 to Asus M5A97 Pro i have some freeze issues at post screen (Asus splash screen). With bios 0813 when i plug in my keyboard ( Razer Anansi with latest firmware 1.02 ) to esata usb ports ( red ones ) my pc ALWAYS freezes at post with the latest bios 1208 it still freezes but sometimes so i'm forced to use the grey usb ports near the ps2 port/lan. Any solutions? btw i can use those red usb ports perfectly fine even with my keyboard but after the windows has booted.
You might want to email their customer support. I have before although the response I got was not very good. For expensive as these keyboards are they leave a lot to desire. I have the black widow and the L key tends to send multiple Ls to the PC instead of just one. Additionally if you use the truecrypt bootloader this keyboard will just start to randomly type characters when you try to input the password and sometimes it won't stop typing until you hit another key. This leads to me having to type the long password at least 5 times normally.
