Asus M5A88-V EVO - Help choosing suitable CPU
dimster
Hello
I want to buy a new CPU for this motherboard. This mobo has 880G chipset which is old, but with BIOS updates it supports the latest 8core E cpus.
I also know that it has 8+1 power phase which is good right?
What I want is to get the maximum possible value for a gaming build. I am not an expert by no means so please correct if I am talking crap.
So after some research I see that FX 6300 is the best value cpu for gaming among the amd cpus. But to get the value from this cpu you need to overclock it right? So will this mobo be able to handle this task?
Also looking at benchmarks I see that up to AMD r9 280x there is no bottleneck for AMD cpus. Above this GPU it is a waste of money to use Amd cpus and people should go with Intel.
Also how about the new FX 8320E cpu? Are they overclocking well or it is too early to say? I suspect in the newest reviews AMD could possible gave some good cpu samples to the reviewers.
I cannot find much info from actual users regarding FX 8320E stock and overclocking performance.
-I have a Scythe Mugen 2 Rev.B cooler so I am planning to use that (still better than stock AMD cooler right?)
-Thermaltake toughpower 500W
Any information is appreciated. Thanks!
http://www.asus.com/de/Motherboards/M5A88V_EVO/HelpDesk_CPU/
Bump?
How about the fact that I want to use an FX CPU on a non 990FX (even 970) chipset?
I have posted on other forums as well and they informed me there are significant revisions made with the intro of this chipset so that they can overclock FX CPUs.
Like Bios features like DIGI+ (CPU LLC, CPU/NB LLC etc). I am confused!
They suggest to get a Phenom II which I do not really like as they are used and old.
