Asus K7M booting problem - help!
theshamu
476
This is very strange, but I have an older PC that is Asus K7M board with Athalon 650 CPU. It was working fine until I took out the 16X CD-RW and replaced it with a 32X drive. Now it would not start, and there's no POST -- the fan would come on, and all lights (HD/CD/Keyboard) would stay on but no display on CRT!
I thought it was memory, but moved/reinserted/swapped with no effect. Could it the CPU is dead? But in that case would the fan comes on? I have not tried to remove the CPU since it is located under the PS and I'm too tired tonight. :(
Any thoughts on what could have happened? I did do one thing wrong - I think the machine was in hibernation mode when I took it apart, but that should just cause a corrupted hibernation file, shouldn't it?
Any help is much appreciated!
Antec 300W PS
256 MB PC133 generic memory
PCI video (ATI Rage Pro)
IBM 20 GB HD
Lite-On 32X CD-RW
Zip 100 IDE drive
NIC
modem
TV tuner card
theshamu
476
Hmm, no one offers a clue? :(
Basically my questions are:
1. Will an Athalon cpu die all of a sudden?
2. Will motherboard still boots (at least the power comes on) when the cpu is dead? I think it would not if I REMOVE the cpu.
Anybody?
GunDog
497
While, I dont think just changing a cdrom would cause this type of problem, I would remove the cmos battery for an hour. I also have a K7M with a 600, when I play around with the bios to much, it does the same thing you describe. Removing the cmos battery has fixed it everytime for me.
I would also make certain the ribbon cable is secured correctly. (again a long shot).
Did you bump the video card?
theshamu
476
GunDog, thanks for the tip! I did figure it was a clearingCMOS-type of problem, but for a while I couldn't figure out how the heck to clear CMOS - there's no jumper! Anyway, I finally found on another board several discussion on problems that are identical, and the solution was to hit RESET multiple times. For me, I had to remove the RESET Switch cable from motherboard!! Now everything is fine after I cleared CMOS.
What a strange problem. :( I knew this board was picky on memory chips, PS and even keyboard. But I had no idea it didn't like the reset sw!:disgust:
Anyway, thanks again GunDog!
