- Sep 2, 2000
- 4,567
- 11
- 81
So I won myself a new K55N laptop from my local credit union. Figured Asus laptops are easily upgradable, so I swapped out the DVD drive and threw in a Blu-Ray which costed $69 - the sale of the DVD drive in there. So $19 invested there.
I upgraded the A8 4500M to a A10 5750M, cpu costed $189 and sold the A8 for $129. So far I am invested $79
Figured I have myself a very usable first laptop. It almost does everything I need it too except for two things. I want to watch movies in full 1080p and have a easier time browsing the web without scrolling so much. I found a 1080p screen for $89 that will fit in nicely with only minor modifications to my mounts. I can not simply swap it out however. The video cable inside this laptop is single channel and will not support 1080p resolution. Anyone know where I can get a duel channel cable for this thing? I tried searching to no avail.
One other thing... not really a concern, Asus web site says max memory on this laptop is 8GB. It currently has 4GB. I want to upgrade the memory to 16GB. Is the 8GB memory limit imposed by BIOS on here? Or was it the older CPU? I was under the impression AMD CPU's have their memory controller built into the CPU. There is no physical pin difference on a 1GB stick vs 8GB on DDR3. 8GB will work for the time being. Just would like it at 16GB.
