ASUS GeForce2 MX/MX 400 w/ TV out help~!!!
alvieshekki
11
I got the ASUS GeForce 2 MX/MX 400 with TV out and for some reason the TV out function doesnot work. I have a Windows XP operating system, i don't know if that is the problem. Can anybody help?!?!?!?!?! :(
hopeless879
900
Make sure your resolution is set to 800x600. You also have to enable TV-out in nView. Go to your display properties, then settings, then advanced. Then click on the nview tab. Force detection of second device. It should detect it.
