Hi guys
My DFI builds is now running almost perfectly (unfortunately I have my memory running CPC disabled for the time being).
The only problem I have is with the graphics card.
2 things really ...
1. The first gold strip on the edge connector (closest to the back plate) on the front of the card is an L shape (i.e. straight down like the others but with a little perpendicular leg at the bottom of the strip pointing to the back plate). The strip is also a couple of mm shorter than all the other strips.
Is this normal ?
2. I didn't use the Asus driver disk to start with. I installed XP Pro, then SP2, then all the DFI drivers and finally downloaded the Asus 808 drivers off the net. I installed these drivers ok. I then downloaded the latest Smartdoc - 460. I double clicked on it to install ... the extraction process started and shortly after the PC hung (no mouse movement). 20 seconds later the PC rebooted.
Upon reboot, there was a 'serious error' dialogue came up and was a system error in the ev log. Here are the details :
BCCode:100000ea BCP1:862F1620 BCP2:86214908 BCP3: F7A1BCB4 BCP4:00000001 OsVer:5-1-2600 SP:2_0 Product:256_1
System log showed an System Error on 4 of the occasions - not all of the reboots.
Details were - Category (102), Event Id 1003.
Error code 100000ea, parameter1 862f1620, parameter2 86214908, parameter3 f7a1bcb4, parameter4 00000001.
I decided to load and run other tests to see if there was a problem with motherboard, memory, disks, CPU.
These were 3DMark05, PCMark04, AquaMark03. All these ran fine to completion (5836, 4481, 68,724(GFX=10,515 & CPU 9,917).
I then ran the latest memtest for 5 hours .... hit no problems.
I then ran Prime95 benchmark, Torture Test - Heat for 3 hours and Torture Test Blend for 8 hours. No errors or warnings.
I tried putting in the Asus driver CD so I could install the older Smartdoc.
The moment it auto ran .... hit same problem .... frozen mouse .... 20 secs later .... reboot.
I then uninstalled 808 drivers, rebooted and installed the ATI Catalyst (latest from today - 5.2). This installed fine. I rebooted. Then tried Smartdoc 460 .... same hang and reboot.
Did a further clean reboot and then tried to access the driver CD again.
Same hang and reboot.
The machine is rock solid until I present it with the Asus driver CD or try to run Smartdoc.
Anyone have any idea what is going on ....
Paul.
2 things really ...
Is this normal ?
Paul.
