ASUS' BIOS updated fried my MOBO - help for replacement suggestion
jaycub
Well no thanks to ASUS' update BS program, I can't reset my mobo apparently (talked to a local computer tech on the phone).
***wish i read this link before doing the update
http://superuser.com/questions/29221/how-to-recover-from-failed-bios-update ***
So now I'm looking for a replacement board that can handle the following
1) Intel Core 2 Duo E6600 2.4GHZ if I recall (99.999%) sure.
2) 8G of DDR2 Corsair 800mhz RAM
3) EVGA 8800 GTS video card.
4 SATA drives.
This was my old board. - Asus P5B
Antec 900 case
4 SATA drives.
http://www.newegg.com/Product/Produc...82E16813131030
My options now are either to contact ASUS and see if they can flash it for me.
Buy a used P5B
or buy one of the following new MOBOs.
http://www.newegg.com/Product/Produc...2E16813131401R
http://www.newegg.com/Product/Produc...82E16813138184
OR
Intel's MOBO which has HDMI - going for a new build in a few months, so this as a HTPC would be an option. Assuming Intel's MOBOs are rock steady.
http://www.newegg.com/Product/Produc...82E16813121389
Any help/suggestions would be greatly appreciated.
Thanks.
