michaeldorian
Anyway guys finally got my quirks worked out regarding SLI. Got SLI enabled on using 2 EVGA 6800U, but now another problem arises. The problems never seems to stop with this dang board. I can't seem to get into Windows XP when I'm using dual monitors on the primary vid card with SLI. With both monitors plugged into each DVI port, the windows progress bar screen would load but just as its about to go into Windows everything freezes and a hard reboot is required. Unplug one monitor reboot and the system boots no problems. When I was running just a single 6800U, dual monitor worked flawless. Is this an isolated case? Has anyone else experience this problem? Any advice on getting this fixed? Anything is appreciated.
Current System Setup
ASUS A8N-SLI
Corsair 3200XL Pro Dual Channel DDR400
OCZ Powerstream 600
2x Raptor 74 GB Raid 0
2X Liteon Drives
Monitor Config.
Primary 6800U (Blue Slot)
Port 1 - Apple Cinema Display 23 DVI
Port 2 - Sony GDM-F520 - Analog VGA
Anything help would be awesome!
ASUS A8N-SLI
OCZ Powerstream 600
2X Liteon Drives
Monitor Config.
