See what you think of this guys.........
I'm aware of the high power demand that the Asus A8N SLi motherboard requires and it seems asus were unaware of the peak load on the 12V rail. Hence the latest bios updates which apparently slow the peak power demand on the PSU and cure about 90% of power related problems with this board. (according to scan and Asus)
However my problem is as follows:
20/12/2004 Got 1 out of a 100 Asus SLi boards that were send to Scan.co.uk
Setup the system and powered up, no problems..... installed windows and few games, SLi worked fine.
But when using the computer again, I noticed that power was not getting to the GFX cards in the PCI-E lanes. This was the same for SLi or single mode. All i got was a flash of the GFX power LED and a slight rotation of the the heatsink fan. From the testing I done, I found that 1in3 times power would get to one GFX card. 1in30 times I would get power to both cards in SLi.
I got onto Scan who stated they were having problems with the board and as a result I RMA'd the GFX cards and the mobo to be sure. Scan did their tests and found that there no power was getting to the GFX cards and that the GFX cards were not faulty.
15/01/2005 Got another board from Chillblast.co.uk and this board behaves in exactly the same way, but worse. I never get power to the GFX cards in single or SLi mode, however many times I try.
1) I have installed 1003 bios update using a PCI card for display, problem persists!
2) I am using a Enermax 600W Dual 12V 18A 17A rail, bought a Tagan single 12V 28A rail to see if this was the PSU that was the problem, problem persists!
3) I have tried single and SLi mode, problem persists!
4) I have taken out CPU, RAM etc... chenged CPU to lower power demand, problem persists.....
5) Cards work ok, tested......
6) All power connectors connected correctly. 4pin molex, 24pin, 4pin ATX and power to PCI-E cards.
7) Check mobo for shorting
8) Cleared CMOS etc as per instructions
This problem seems more than just PSU related, I have eliminated the PSU, bios updated, just seems so fundamental. Simply power is not getting to those cards, but why? they work ok!
Is ayone else getting this problem, I would really need to know if I'm unlucky enough to have two faulty boards or if there is a problem I can reslove?
SYSTEM
Noisetaker 600W dual rail 18A 17A or Tagan 480W single rail 28A
FX-55
XFX 6800GT x 2
Asus A8N SLi Deluxe Mobo
Raptor 74GB
Audigy 2ZS (not conected)
CM stacker Case
Asetek water cooling (not connected)
22" Iiyama Pro 513
SYSTEM
FX-55
XFX 6800GT x 2
Raptor 74GB
CM stacker Case
22" Iiyama Pro 513
