I'm using 4 x 512M OCZ Platinum 2.0 set at 2-2-2-5, 2T, and 2.75 volts. I've tried 007 BIOS, but right now I've got 009 Beta in there.
Even if I set FSB at 200 MHz, the CPU at 10x, the memory at 333 MHz, and HTT at 4x, the thing spontaneously crashes. From there, I dropped the CPU to 5x, the memory to 266, HTT to 3x - and it still crashes at random times.
I've tried FSB at 240 MHz, the CPU at 10x, the memory at 333 MHz, and HTT at 4x, and it is almost stable. It might crash after a few minutes, few hours, or 1/2 day. Actually, it performs better at higher speeds.
I've systematically tried to isolate overclocking the CPU, memory, and HTT bus. But no matter what speeds I try it still crashes unexpectedly every so often for no apparent reason.
I've tried not only slowing down memory but changing the timing to 2.5-3-3-8 - and it still crashes.
I've tried bumping up the CPU voltage and the HTT voltage - and it still crashes
I've tried 6.66 and 6.65 (currently installed). I've had the nForce stuff installed and enabled and (currently) uninstalled and disabled - and it still crashes.
I've tried running Prime 95 and OCCT after a fresh windows install and SP2 upgrade (from a file on HD) with no LAN installed and no board specific drivers installed - and it still crashes.
I've tried installing ALL current downloaded drivers, including 6.65, BIOS 007/008/009, AMD X2 drivers, etc. - and it still crashes.
As I said, I swapped out the motherboard with another A8N SLI Premium - and it still crashes.
I've tried swearing at the computer and threatening to tie it behind my car and drag it down the freeway at high speeds - and it still crashes.
I've tried many other things not listed, or that I can't even remember - and it still crashes. I've been fighting this computer from hell for almost a month now.
Sometimes, it seems to start working more reliably and I think that I've solved the problem. This happened after I first dropped the HTT to 4x and also when I installed the AMD x2 driver - but then after about 1/2 day the crashing returned.
The crashing is sometimes a blue screen, sometimes a mouse freeze, sometimes a spontaneous reboot.
I've tested memory with MEM86 from a floppy and it passed for days... But *once* I looked at the screen and saw 3 errors. But that was just once a couple weeks ago. I've never seen another MEM86 error since.
Could it be CPU? Power supply? Everything is brand new and supposedly good quality. I'm ready to sell the whole thing "as is" on Ebay and buy a completely different system - no Asus, no AMD, no OCZ memory, no OCZ power supply, etc. This whole experience is CRAZY.
Robert.
ASUS A8N-SLI Premium
WinXP Pro
6600 GT
Samsung Spinpoint 160 GB SATA2 8 MB - System Drive
WD 250 GB SATA2 16 MB - Data Drive
AMD X2 3800+ with Zalman CNPS7700 heat sink
OCZ Powerstream 520 W supply
Antec P180 Case
Benq DW1640 DVD
Mitsumi FA404A Floppy with card reader
Hauppauge PVR500 2-tuner TV card
